compression/cam questions
Hey guys, I was originally just going to freshen my 305 maybe do alittle to it but through persuasion on the site
ive decided something bigger. I was originally thinking just a 350 but i kinda want to do something a little unique. I was thinking about running either a 327 or a 383 stroker. Now for the question. Will my stock computer..obv with a diff or recalibrated prom.. beable to run my tpi setup on either of these and are there any compression or cam limits I should adhere to so it will actually run. Now I will answer this before I get asked... It is a 91 MAP TPI setup..off of a 91 305 F code engine that stock made 230 hp and 300 ft.lbs. I would appreciate any suggestions/ all info on the subject. Thanks
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: compression/cam questions
the car will run. but you will need 24# Injectors. the Eprom tune will need to have 350
Parameters if more mods are done.. more Eprom tweaking will be required
