Timing issue won't start
Old Oct 29, 2009 | 07:59 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
I have a pontiac 350 I'm working on. The dang thing will not start unless it has an ungodly amount of timing. I mean so much that I can't even see the mark cause it is under the engine. I thought maybe the balancer had slipped but if I put the crank at 0, #1 is at TDC. It runs like butt once it fires.
Any ideas?
Old Oct 29, 2009 | 08:33 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: Timing issue won't start
Your distributor would be 180 degrees off. Or the timing marks on the cam and crankshaft isn't configured correctly. If it hasn't had the timeing cover off the timing chain is bad and jumps. Or missing teeth on the gears itself.
Old Oct 29, 2009 | 10:24 PM
berlin305's Avatar
This is not a conclusion just IMO whats going on here. Just to clear that up.
Old Oct 29, 2009 | 10:41 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
funny thing. it runs now. I changed nothing. I went out to start it wouldn't start. wtf? so I turned the cap back and got it to about 12* and started right up. Dialed into 9* and it lights up quick and easy. I have no clue but I'm glad the car gods blessed me for today
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
