RHS 12335 Heads on a 305 (200cc in/76 out/50cc chamber/2.02in valves/1.6 out
Old Oct 30, 2009 | 02:00 AM
chcgobearsfan3's Avatar
Car: 90 camaro RS
I'm assuming lift under .400 will work fine, yes?
Old Oct 30, 2009 | 05:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: RHS 12335 Heads on a 305 (200cc in/76 out/50cc chamber/2.02in valves/1.6 out
Why would you put a 200cc head on a 305?
Most run 195's on 383's
What is your compression going to be with a 50cc chamber?
Old Oct 30, 2009 | 05:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You're kidding right?
Those high end heads, and you won't to know if lift under .400" is ok?? I assume that's a typo?
And yes, 200cc heads on a 305 will run VERY poorly under 3500 RPM or so.
Wait, wait, aren't you the same guy from that other goofy thread I posted on a few days ago? From a quick glance it looks like some real experts have come in there to set you straight. I hope you don't require that assistance in this assinine thread as well?
FWIW - 50cc heads will give about a 10.5:1 or so, given flat tops on a 305.
Old Oct 30, 2009 | 05:19 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Based on your other thread, I think you need to take a step back and do some research and learn some basics before tying to move forward with your 305. The setup you propose is a mis-match from hell.
Old Oct 31, 2009 | 10:40 AM
Guest
Guest
Posts: n/a
an LO3 is said by Atilla to be 8.8:1 stock with 55cc. So the 180cc version of these, or the EngineQuest offerings, which I'm sure exist as 180cc with 50cc, would then be around like 9.2:1 unless you use composite headgaskets, then you'd be around 9.0:1. Edelbrock claims that if you use their 2.02"-valved heads on a 305, you can only run 0.450" valve lift. There are lift rule cams for dirt oval racing, and COMP offers a bunch of .450" hydraulic roller lobes. Still, even with 180cc I'd think a 3000-stall and 4.10:1 would be in order.
Old Oct 31, 2009 | 05:27 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I can see the heads working on a limited class track engine but for the street why would you run a big valve hi flowing head and then limit it's output by restricting the lift
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
