Piston Ring Gap Direction / Clocking
Old Oct 31, 2009 | 08:30 AM
AC's Avatar
AC
Car: Used to drive a camaro
So my rings are filed and ready to put on the pistons, then pistons into the bores.
Question: When clocking the ring gaps on the pistons, if I were to look at the left & right banks (say cylinder #1 and #2) do both pistons have their top compression ring gap in the same position, say 3 o'clock and the 2nd comp ring at say 9 o'clock. Should I position all pistons with this scheme
OR
Would #1 piston have top comp ring at 9 o'clock and 2nd comp ring ring at 3 o'clock and #2 piston have top comp ring at 3 o'clock and 2nd comp ring at 9 o'clock. (Essentially opposite among left and right bank pistons.)
Old Oct 31, 2009 | 09:32 AM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: Piston Ring Gap Direction / Clocking
I always gap em 180 degrees from each other and slide em in the cylinder. Wonder if thats right also?
Old Oct 31, 2009 | 09:43 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have always put them 180 degrees from one another . i have done this on auto engines , motorcycles , and acft. engines . has always worked for me . good luck .
CatmanFS
Sep 19, 2015 09:00 AM
dimented24x7
Sep 17, 2015 06:58 AM
BOOT77
Sep 16, 2015 08:37 PM
DARKmj16
Sep 9, 2015 04:07 PM
BOOT77
Sep 5, 2015 03:55 PM
