Removing air lines from manifolds?
Old Nov 2, 2009 | 12:09 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
My car already has the smog pump removed, and I'd like to remove the air lines if possible. All they do now is get in the way when trying to change spark plugs. I know some people have had mixed success by just unbolting them and putting in threaded plugs, but mine don't want to budge. I'm sure I'd just round off the fittings. Has anyone tried cutting the tubes off flush with the fittings, and welding them shut?
Old Nov 2, 2009 | 12:51 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Removing air lines from manifolds?
If you think you are going to round them off, just cut the tubes off of the fittings then use a 6-point socket. Don't use a cheap socket. I broke a Craftsman socket removing mine.
Old Nov 2, 2009 | 01:44 AM
89 brewcity's Avatar
Car: 1989 firebird
Engine: 350 tbi
Transmission: T5 5speed
if you use a air hammer with the chisel bit a just zap them it will cut the pipe and pinch it closed in one shot. I do this all the time with amateur dirt track cars.
Old Nov 2, 2009 | 04:01 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Or you could wake up in the morning and spray all of them with penetrating oil, then come back in and eat breakfast. When your done eating breakfast, read a newspaper/magazine for a little bit and then go spray them again. Come back in and do some other chores, and after another hour, go back and do it again, and again, and again... I did it maybe 3 or 4 times and then used a tubing wrench and they all came right off. No rounding or cutting required.
Old Nov 2, 2009 | 10:59 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Thanks guys, I may just try to unscrew them the 6-point socket idea is good, I didn't think of that. I'll also try the penetrating oil, i've seen that stuff work miracles before. I'd prefer not to cut them and pinch them off though, someone did that on my old 83, and i can't even remember how many times I cut myself on those things.
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
Jake_92RS
Aug 11, 2015 10:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
