tpi ho's?
Old Nov 2, 2009 | 09:15 AM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
tpi ho's?
are the any tpi high output engines?
Old Nov 2, 2009 | 09:18 AM
IROC_U's Avatar
Car: 1991 Z28 Camaro
Engine: 355 sbc
Axle/Gears: 4.10
Re: tpi ho's?
My TPI puts out quite a bit haha but im pretty sure thats not what your lookin for, im assuming you mean a factor TPI High Output engine?
Old Nov 2, 2009 | 09:37 AM
Engine: V8 305
Re: tpi ho's?
yes i do mean a factory tpi h.o. my brother recently bought an 86 iroc and it says on the car 5.0 high output
Old Nov 2, 2009 | 09:47 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: tpi ho's?
TPI was the "High output" of the 305. That is how it is generally referenced a TPI motor in many books, publications, along with the side of the cars. There was no internal modifications outside of differences among years to the TPI system to make the motor a true High (or higher) output than the car sitting next to it in the dealerships when sold as new.
Old Nov 2, 2009 | 12:11 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Re: tpi ho's?
The '86 tpi may not feel too high output though. That was (one of) the worst year(s) for them. GM put a tiny tiny cam in them to avoid a gas guzzler tax being put on the car. In later years they got past that tax with a shift light lol.
Old Nov 2, 2009 | 12:15 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: tpi ho's?
"5.0 high output" usually refers to the L69, the carbed engine that was available from 82-87. There was no stock TPI setup referred to as "high output", although I guess you could consider the 350TPI the "HO" version :P
Old Nov 2, 2009 | 12:18 PM
84redta's Avatar
Re: tpi ho's?
I've seen 5.0L High Output on the side of a tuned port trans am. When i ordered my 85/86 trans am decal kit from pheonix graphix it came with 5.0L High Output or 5.7L High Output decals.
Edit, sorry... 5.0 Litre H.O. is how it was worded.
Maybe the cars I've seen were incorrect, because there is also a 5.0 Litre F.I. option available as well in later years. But pretty sure it started in 85 to like 87 as 5.0 HO was the TPI 305, and then in like 87 or 88 they showed the 5.0 Litre F.I. Could be wrong but going off of the cars i've seen original with tpi.
Old Nov 2, 2009 | 06:20 PM
Engine: V8 305
Re: tpi ho's?
yeah, it says
5.0 litre H.O
tuned port injection
something like that. i will snap a picture when i get a chance
Old Nov 3, 2009 | 01:36 PM
Engine: V8 305
Re: tpi ho's?
Here is a picture.
Old Nov 3, 2009 | 07:29 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Re: tpi ho's?
My '83 Z28 with the 5.0 HO carbed engine (IIRC) was rated for 190 HP and 265 ft. lbs. of torque. My '86 IROC Z28 with the 5.0 TPI engine was rated for 190 HP and 285 ft. lbs. of torque.
The difference in the way they run when the have the same HP and the TPI has more torque? The '83 winds up to 5500 rpm and shifts pretty quickly. The '86 winds up to about 4500 rpm pretty quickly and then takes nap from 4500 to 5500 rpm when it finally shifts. That 5500 rpm foot to the floor shift point was a mistake on the TPI engines. They struggle to "breathe" above 4600 rpm.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
