Distributor Bolt (English or Metric)?
Old Nov 2, 2009 | 04:53 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Hey fellas,
Title about sums it up. Car's six miles away and I need to order a distributor wrench so it gets in this weekend. Do I need a 13/15mm wrench or a 1/2-9/16" wrench?
Muchas Gracias,
-Levi
Old Nov 2, 2009 | 04:59 PM
wannaz's Avatar
Car: 90 iroc z
Engine: 350 needs work
Transmission: 700r4 needs work
Re: Distributor Bolt (English or Metric)?
mine is 9/16 on my 90 iroc
Old Nov 2, 2009 | 05:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It takes a 9/16"
You use a distributor wrench? Why not just the open end of your normal wrench?
Old Nov 2, 2009 | 09:08 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by Sonix
It takes a 9/16"
It's probably on the TPI engine. The EGR solenoid and coil block it completely. One of the few times you need a "bonafide" distributor wrench.
BTW, Sonix when are you gonna bump your compression to 14:1? It's the same as running a blower, you know...
Old Nov 2, 2009 | 09:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
oh ok... There's my ignorance showing I suppose... I never did figure out what made those tools so popular..
haha, as soon as I pick up some epoxy to goober on my pistons to make some home made pop up pistons i'll be set! Then just add some cheap rocket fuel to my gas tank to add the octane needed and it'll be cheaper too! Right? Just POUR some rocket fuel into my gas tank eh?
mddaniel
Sep 8, 2015 05:16 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
86IROC112
Aug 17, 2015 07:57 PM
