PCV system...
Old Nov 5, 2009 | 03:52 PM
red30011's Avatar
PCV system...
Just was wondering what people where using for this system. My car had the simple little breather caps on the valve covers but was considering going with a newer style system. Maybe find a vac line on the intake and put a pcv valve somewhere and pump the gases back into the intake? The stupid breather filters cost me 10 each... Didn't know if the newer system being put on cars was alot more effective or if the difference was so minimal that it would be worth my time? Just curious
Old Nov 5, 2009 | 04:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: PCV system...
The "newer " system has been around since the '70's.Yours is not stock.
Using vac to draw the fumes out of the engine is more efficent than just allowing them to dump out on their own
PCV valve fits in a grommett in one cover
Old Nov 5, 2009 | 04:08 PM
red30011's Avatar
Re: PCV system...
heh,didn't know that. Thought they started that around 90s or so. Kinda figured it might have had that once but wasn't sure. All I need to do is use the vac line to dump the gases somewhere in the intake right? Can you tee off a vacuum secondary line or brake booster line or need to find a separate vac source? Sorry, just don't know a whole alot on this.
Zach
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
Pac J
May 17, 2020 10:44 AM
NZKnight
Oct 15, 2015 02:47 PM
sleprock
Sep 24, 2015 04:33 PM
R13_Braz
Sep 18, 2015 05:00 PM
