what are these two devices?
Old Nov 6, 2009 | 10:29 AM
Tonglebeak's Avatar
Car: 1986 Camaro Z28
Engine: 305 4bbl
While "doing some work" to the AIR system, I found a couple of broken hoses, and they're attached to these devices.
What are they? Thanks.
Old Nov 6, 2009 | 10:46 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: what are these two devices?
The second one is your charchol canister. I cant tell by the pic of the first one but its something for your vaccum lines.
Old Nov 6, 2009 | 10:47 AM
Tonglebeak's Avatar
Engine: 305 4bbl
Sorry about the blurry pic. It seems my camera's autofocus doesn't work to well in mixed light situations.
What exactly is the charcoal canister for? I see it has two hoses on it. One says Carb, and the other says Tank. One of those hoses (I think the one that says Carb) runs to that device in the first pic, which has a couple of hoses pinched. Lemme see if I can take a clearer pic.
If it helps, it says "Rochester Products" on it.
Old Nov 6, 2009 | 12:35 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
It stores the fumes from your gas tank and then feeds them to the engine when it's running. It's part of the emissions control system.
Old Nov 6, 2009 | 01:48 PM
racethesunlive's Avatar
Car: '92 Camaro
a heater diverter valve maybe? http://shop.advanceautoparts.com/web...S_888737409___
Old Nov 6, 2009 | 01:53 PM
Tonglebeak's Avatar
Engine: 305 4bbl
That looks similar to the heater valve...
If it is emissions stuff, then out it goes! I did trace a couple of lines. One goes straight into the carb (well, it was broken in 3 pieces when I bought the car :\), one appears to go underneath the car somewhere, and I can't remember if there were any other hoses.
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
camarohelp
Sep 12, 2015 05:45 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
theurge
Aug 21, 2015 12:46 PM
