Fuel pressure won't hold after pump cuts off
Old Nov 7, 2009 | 07:47 PM
JMAC71's Avatar
Hey guys,
Thanks for having me and hopefully you can help me. I have a 1997 Firebird. 3.8 Liter. My card is hard to start first thing in the morning or anytime after it sits like for an hour or so. I have checked the fuel pressure. I have 48 PSI when you turn the switch to on and the fuel pump engages. After the pump shuts off (approx. 2 seconds) the fuel pressure just drops. In less than a minute it has dropped to zero or very close to it. I am thinking the check valve in the fuel pump is bad? Let me know what you think. Once I turn the car over for 3 or 4 seconds it starts and runs fine once it starts. My other question is: If I have to replace the pump isn't there a procedure where you can do this through the trunk without dropping the tank? If so, does anybody know the measurements or a pattern to go by in order to cut the access panel. I have been told by several that this is far easier than dropping the tank. Any help will be greatly appreciated.
thanks in advance,
JMAC
Old Nov 7, 2009 | 08:47 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Fuel pressure won't hold after pump cuts off
97?
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Brcharrelson
Aug 26, 2015 07:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
