crazy idle issue 87 gta
Old Nov 10, 2009 | 05:35 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
Hi all
Im having a issue. no codes but when i get to stop like the idle goes up to around 1k, if i tap the gas a couple of times, it goes back down. I didnt see any broken or cracked hoses. Any help would be great. thanks for lookin
Old Nov 10, 2009 | 05:42 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: crazy idle issue 87 gta
Originally Posted by TOM305T/A
Hi all
first things first check and clean the IAC/TPS. Check out the technical faq link on this site for a how to, theres lots of info on common issues there.
heres a link with pictures also
http://www.iroczone.com/2009/10/adju...on-sensor-tps/
Old Nov 11, 2009 | 09:28 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Yes this is most likely a problem with your iac or tps. However, the first thing you need to do is take your air intake off and clean the throttle plates and throttle body REALLY well. These get extremly dirty on tpi motors due to the location of the egr valve. Clean your throttle first, see what that does, and then check your tps voltage and remove and clean your iac valve. Good luck!
Old Nov 11, 2009 | 08:21 PM
TOM305T/A's Avatar
ill start with cleaning the tb, thanks
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
