idle and timing?
Old Nov 15, 2009 | 06:16 PM
82blackout350's Avatar
Car: 1982 Camaro
Transmission: saginaw 4spd manual
idle and timing?
for some reason, when my car is idling high, it wont let me put it into gear (it has a 350 with a 4spd manual) but when i turn the idle idle down, it shifts like a dream. And its been doing this since ive got it. on the quadrajet 4bl i have both pins turned out 1 1/2 turns. sometimes it will idle low and then sometimes it will idle a bit higher an not let me put it into any gear. Could the timing be advnaced to much? or is it a whole different problem?
Old Nov 16, 2009 | 07:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It should be able to go into gear at any RPM.
You might have a pilot bearing/bushing problem.
Old Nov 17, 2009 | 06:39 PM
Car: 1982 Camaro
Re: idle and timing?
ill have to check that out, its weird though cause when its idling high it wont let me put it into gear
but when i lower the idle, it works just fine? kinda confusing me
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
perZ
Aug 15, 2015 01:17 PM
