excelleration problem
Old Nov 15, 2009 | 07:27 PM
retrovet's Avatar
Car: not bad for a 65000 proam $1500 buc
Engine: 305 326 400 455
Transmission: powerglide turbo 400 700r
recently updated thread 1987 305 carb complaint
Old Nov 15, 2009 | 08:03 PM
redtruck18's Avatar
Car: 1987 RS Camaro
Engine: 305 V8 (Carb)
Re: excelleration problem
Was the car origionally carb'd? or fuel injected? It sounds like it may be a fuel pump problem, generally fuel pumps send fuel in fluid motion (not pulsating)
Old Nov 17, 2009 | 04:58 PM
retrovet's Avatar
car is original carb 305 installed new fuel pump today starts easier but still off idle poor excelleration did notice a large flow coming out return line back to tank almost as if pump was working . blew compressed air thru both lines to tank but found a large vacume when removing gas cap . please any ideas im a old pontiac guy my first chev powered pontiac with flat spot off idle????????
Old Nov 17, 2009 | 05:58 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
I don't believe you mentioned what carb it has.
p.s. it's "acceleration".
Old Nov 17, 2009 | 08:00 PM
retrovet's Avatar
your correct aceleration! it original equiptment chev 305 with original quadrajet electric control main metering? at times previously found heavy start up smoke white/blue intermitently .when occurs very slugish throttle . carb was rebuilt previous to purchase looked in air horn when vehical was off pumped acerator pump dry like older quad that ball not seated . disassemble carb lip seal looked good replaced same occurance. replaced fuel pump today same hesitation no smoke start up? found return line which goes back to tank to be flowing large volume even filled pump and carb . vacume in gas tank when opening ??? any other info adjusted timing no change ?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
