9.5:1 Compression ratio????
Old Nov 17, 2009 | 07:33 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
I have th 83 Camaro CFI That has the cam from a 350 and gives it a 9.5:1 Compression ratio and i heard it runs best on 92-94 Octane. Is that true, and where can i get 94 octane at, its not pump gas, and would 95 octane from vpracefuel be fine in the engine. It is stock except for an exhaust and the airfilters but the 305CFI in '83 came with the 350 L69 Cam or something giving it a "high performance" 9.5:1 Compression ratio as they said. Please Let me know, I know that i can run reg 93 pump gas but I want to just see how much better it does on 94 or 95 if y'all think it is safe
Old Nov 17, 2009 | 07:59 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: 9.5:1 Compression ratio????
i thought it was cylinder volume that gave an engine compression. not the cam. although the wrong cam can bleed off compression. most cars today run 9-5-1 compression and they can run on 87 octane. 94 not sure on that. i know there is 93 here in texas. i run it all the time.
Old Nov 17, 2009 | 11:17 PM
DJ_91RS's Avatar
Car: 91 RS, 89 IROC
Engine: 305 TBI, still deciding
Transmission: 700R-4, still deciding
Axle/Gears: stock, 3:73 IROC
You wont notice a difference from 93 octane to 94 or 95. You won't hurt anything either except your wallet. Only need to run high enough octane to stay out of detonation.
Old Nov 18, 2009 | 12:10 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
it is the heads and pistons that determines the C/R
The CFI engines have electronic spark control with a
knock sensor-if pinging is detected the ECM will pull
back the timing advance,reducing power until no more
pinging or"knock"is detected. the L69 carbed engine
also had electronic spark control and GM rated that
engine at 190HP,200HP if high octane gas used.
Old Nov 18, 2009 | 02:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Depends on your gas stations. Mohawk sells 94 octane at the pump here in Calgary.
9.5:1 CR does NOT need any more then 87-89 octane. I doubt you have more than 9.5:1 CR anyway, and yes, a cam does not determine CR, the heads and pistons and crankshaft do.
What on earth engine do you actually have??
Old Nov 18, 2009 | 02:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A cam, in combination with the cylinder and combustion chamber volumes, affects the dynamic compression ratio. But, 9.5:1 is the static compression ratio.
FWIW, I'm running 9.7:1 on 85 octane (high altitude regular unleaded). At the track, it does slightly better on 87 octane.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
