Accelerator hard to push at first, then loosens
Old Nov 19, 2009 | 10:18 AM
olin305's Avatar
Car: 1988 Firebird Formula
Engine: LO3 - 305 TBI
I don't know if this is normal or not, just wondering, but when I start my car from a cold start, the accelerator has a lot of resistance to it, then after the engine warms up it loosens up a lot, it's a little annoying because I drive stick. Has anybody else experienced this?
Old Nov 19, 2009 | 11:17 AM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: Accelerator hard to push at first, then loosens
Not sure if TBI has throttle springs or not, but on carbs i know if the throttle spring is to hard it can make the pedal hard to push. like i said not sure if that applies to TBI but it would be worth the try to swap throttle springs and see if it helps. (if it has a throttle spring not sure if they do).
Old Nov 19, 2009 | 03:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I would start by disconnecting the cable at the TB end and see if it moves freely.The cables can wear with age and bind up.
Also check that the TB shafts and linkage are free to move
Old Nov 22, 2009 | 08:42 PM
Pocket's Avatar
Car: 91 Trans Am
Its common on TBI cars
When the TB is 100% closed it creates a semi seal and the vacuum of the engine tries to keep the blade closed. Degumming the sludge with TB cleaner helps but the problem will never go away short of drilling a hole in the butterflies. Then the idle will be funky
No win situation
Old Nov 23, 2009 | 01:45 PM
ty_rich's Avatar
Car: 1986 IROC-Z
Engine: 8100 Vortec (496ci)
Transmission: 4L80E (4spd auto)
Axle/Gears: 9" 40 Spline Detriot Locker 4.90
i think you need to just clean your throttle body, i bet its sticking a little bit too...if it were springs/cable it would be constant...
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Breazlan
Sep 25, 2015 11:20 AM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
