Pulley swap possibilities?
Old Nov 19, 2009 | 09:05 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Is it possible to put the pulleys from a serp setup on the accessories of a v-belt setup?
Old Nov 22, 2009 | 08:39 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Pulley swap possibilities?
Crank/smog will bolt on
WP will bolt on, but be aware serp WPs are reverse rotation. V belts and std rotation
Alt/PS can be changed with a puller
AC requires a new clutch unit. Rent the puller tool
That being said, youll have no mount for the tensioner and the belt length will be hard to determine unless you got all the brackets and no indiv accessories
Old Nov 22, 2009 | 09:36 PM
Car: 1987 IROC-Z
Transmission: TH350
I have no need for the smog or AC pulley's. I figured the water pump would need to be changed. I'll just borrow the puller from a friend.
Does anyone know if the tensioner can be seperated from the giant serp bracket, and can anyone provide me a good picture of it and how it mounts and/or moves. I don't want to use the giant ugly brackets for the complete serp setup. I plan on making my own serp setup using my v-belt accessories. It will be way cheaper and probably just as good looking as the march setup when I'm done. Ok, maybe not as good as the fancy-pay-insane-$$ march pulley setups, but it will look good. If the tensioner won't work, I can always go without it. Not a big deal...
Old Nov 22, 2009 | 11:05 PM
Pocket's Avatar
Car: 91 Trans Am
Its held on by a single shoulder bolt. The base has a small nipple that fits into a recess in the bracket to put tension on the spring. A flat plate with a nut on the back and a hole drilled for the nipple is all you need
I reused the stock tensioner here and thats how I mounted it
https://www.thirdgen.org/forums/fabr...-firebird.html
Old Nov 23, 2009 | 10:56 PM
Car: 1987 IROC-Z
Transmission: TH350
Do you know if the crank pulley meant to work with a short water pump will be usable with a serpentine belt setup? I know the short water pump was only from on cars up to 68 and on trucks up to 72, but is there a stock GM pulley that will work?
Old Nov 23, 2009 | 11:25 PM
Pocket's Avatar
Car: 91 Trans Am
Im not sure
I do know you need a car or LO5 truck pulley. Others will be too short
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
