1982 camaro backfire
Old Nov 22, 2009 | 04:58 PM
jiom710's Avatar
Want a title? Post!
Car: 1982 camaro berlinneta
Engine: 2.8 v6 carb model
Transmission: auto
hi hope someone can help i have since bought a 1982 camaro 2.8 carb model the person before had left it for dead the problem i have is it will turn over maybe about six times then it starts to backfire through the exhaust i noticed that the distributor was 180 degrees out so i set it up top dead center and replaced the distributor back in now the backfire is coming up through the carb i have checked the firing order and the set up of the leads
please help
john
Old Nov 22, 2009 | 05:42 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
Re: 1982 camaro backfire
are you sure you set the timing correctly?
Old Nov 22, 2009 | 07:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Either your firing order is off, or you've got a bad plug, or bad plug wire.
Leave the distributor where it is, make sure again #1 cylinder is TDC on compression stroke, the take dist cap off - wherever rotor points, that is NOW your #1 plug wire - make sure that wire runs to #1 cylinder - then follow the firing order.
Also, check each plug and make sure they are firing.
Also, check each plug wire, one at a time, for continuity with a volt/ohm meter - there should be very very little resistance on any of them. Even if they are new wires, check them - can't tell you how many bad "new out of the box" wires I've bought over the years.
BADNBLK
Nov 16, 2016 09:12 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
db057
Aug 22, 2015 08:17 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
