original camshafts
Old Nov 22, 2009 | 10:42 PM
skyhigh4by's Avatar
Car: 2004 GMC 2500HD
Engine: Duramax LLY
Transmission: Allison
original camshafts
Im in the process of switching the blown 305 from my 85 with another 305 from a truck. The original car motor casting number is #14010201 and the one from the truck is #14010203. The car has original 416 heads and the truck motor has #376450 heads. Im going to be putting the 416 heads back into the car but Im just wondering if the camshafts might be different between the 2 motors. Would it be worth it to swap it over also?
Old Nov 27, 2009 | 04:50 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: original camshafts
I would swap it over. Simply because you don't want to get that motor in there and then discover that the truck cam is less agressive than your original stock roller cam. They are usually not as good as the car's camshaft. Also, you may have to get your prom reprogrammed for the truck cam. Probably run you about 300 bucks or so.
Old Nov 27, 2009 | 05:17 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Dont think the 85 had the roller cam yet..... This would be a golden opportunity to upgrade the bumpstick a bit though......
Old Nov 27, 2009 | 06:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
All the stock cams are so wimpy I would not bother.
87 F 305 auto 179 /194 dur .350/.384 lift
If the truck motor is factory roller cam block ,consider putting in a stock LT1 cam ; can be had over in parts FS for next to nothing ; cheap upgrade
Stock LT1 202 /207 dur .450/ .450 lift
Old Nov 27, 2009 | 06:33 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The difference in specs would be so little the ECM won't notice
db057
Apr 28, 2019 07:45 AM
Whata69
Mar 2, 2016 06:34 AM
machinist21
Sep 5, 2015 03:03 PM
greenyone
Sep 2, 2015 03:39 PM
