Hard starting tpi 305
Old Nov 23, 2009 | 04:11 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Hey guys, this is my first post here about my new car. Its a 1988 formula ws6 305 tpi, 5 speed. When i et in it and start it, it starts really easy and fast if it is cold. But when i get in it after I get gas or leave the store and it has already been running recently, It starts rather hard. Its like it cranks for about 5 seconds instead of about 1 second. Any ideas will be great thanks guys.
Dustin
Old Nov 23, 2009 | 05:48 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: Hard starting tpi 305
I'm having this same issue with my formula 350. It's carb'd. Starts great cold but when it's heated up takes a few seconds.
Old Nov 24, 2009 | 03:59 PM
1badeagle's Avatar
Engine: 370 LSX
Ok then, Can anyone help to guys with hard to start cars?
Old Nov 24, 2009 | 04:23 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Hydrolic: You problem is going to be different than 1badeagle's, please start a separate thread, gets too confusin' otherwise.
1bad: If you step down on the gas pedal, will it fire right up when warm? You might have injectors leaking down, leading to a bit of a 'flooded' condition when the engine is warm. (first start of the day, that gas has had chance to evaporate.)
Old Nov 24, 2009 | 05:57 PM
1badeagle's Avatar
Engine: 370 LSX
No, it still starts hard if i push on the gas pedal. It just starts hard when its warmed up. You think its an injector problem. Could there be an issue with the fuel pressure regulator.?
Old Nov 24, 2009 | 06:02 PM
ploegi's Avatar
Engine: 5.7 TPI
I would think if it was the fuel pressure regulator, engine temp wouldn't matter. You could beg/borrow/steal a fuel pressure gauge, screw it on, and see how fast fuel pressure bleeds down when you shut the engine off... This isn't a perfect test though, as the fuel may be bleeding off back into the tank.
Next time the car is warm, press the gas pedal to the floor when you crank it up, and see if it makes any difference. (let off as SOON as the engine fires....)
Old Nov 26, 2009 | 08:28 AM
1badeagle's Avatar
Engine: 370 LSX
ok, ill try that in a little bit.
Old Nov 28, 2009 | 08:02 PM
1badeagle's Avatar
Engine: 370 LSX
The previous owner told me he thought it may need prom tuning since the ac and all smog are removed and it has been converted to a bw t-5 from the automatic. Does this sound like a possible cause?
Old Dec 15, 2009 | 06:13 PM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
my car had the same prob when i bought it it was the injectors leaking down. heard it spraying when i changed the plugs did a leakdown test, and realzed why i had the same problem as you do or did if u already fixed it.
Old Dec 16, 2009 | 01:54 PM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
I've got a 305tpi with a T-5 that does the exact same thing. I posted a thread about it a couple months ago but didn't get much help. I have checked the resistance on my injectors and they are all within range. How do I know if my injector(s) are leaking?
Old Dec 16, 2009 | 01:56 PM
Car: 1988 GTA
I've got a 305tpi with a T-5 that does the exact same thing. I posted a thread about it a couple months ago but didn't get much help. I have checked the resistance on my injectors and they are all within range. How do I know if my injector(s) are leaking? My car does start immediately if I press the accelerator to the floor.
Old Dec 16, 2009 | 02:33 PM
Car: 1988 GTA
Ploegi you seem to know a lot about this. Are leaking injectors my problem?
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
drathaar907
Aug 6, 2015 04:20 PM
