Not starting. Fuel Problem
Old Nov 24, 2009 | 04:41 PM
90IROC305's Avatar
Car: 1990 IROC-Z
Engine: lb9
Transmission: t56
I have a 90 IROC with a 5.0 TPI. The car wont start just cranks and cranks. I checked the ignition and all is good. Checked fuel pressure it was at 5psi. Changed fuel filter now its at 10 psi. Still not enough supposed to have 40-47psi. I'm thinkin the pump is bad, but before i tear into it does anyone else have any ideas. I can't find any visible leaks and dont smell any fuel. Any ideas would be helpful.
Old Nov 24, 2009 | 04:48 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Not starting. Fuel Problem
Your first instinct is probably correct. If you hear the pump run, there aren't any restrictions in the fuel lines, and the filter is nice an new, and there aren't any leaks.... sorta only leaves the pump. It is also possible that there is a problem inside the tank.... but, either way, you have to drop the tank out.
Old Nov 24, 2009 | 08:47 PM
90IROC305's Avatar
Car: 1990 IROC-Z
Engine: lb9
Transmission: t56
thats what I figured thanks for the thought. Gunna be a great way to spend Thanksgiving morning.
Old Nov 25, 2009 | 12:31 AM
ploegi's Avatar
Engine: 5.7 TPI
Might wanna check the regulator? Not sure, but a holed bladder might cause that too? (of course, you would see gas in the vacuum line too...... something to check anyway.)
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
