Belt Alignment
Old Nov 24, 2009 | 10:14 PM
Allamericantc's Avatar
Car: 87 TA
Engine: 355
Belt Alignment
I have the v-belt set up. I took out the a/c. Do I need to put in a spacer behind the power steering bracket because the p/s pulley is out of alignment. I attached the best pick I could take.
Thanks for any help!!
http://img264.imageshack.us/i/p1020924.jpg/
Old Nov 25, 2009 | 11:23 AM
Car: 87 TA
Engine: 355
Re: Belt Alignment
Anyone?
Old Nov 25, 2009 | 11:44 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Belt Alignment
So long as you have one belt that lines up nicely, and is tensioned properly, you should be ok. Don't really need two on there, as most cars used only one to drive it in any event.
Old Nov 26, 2009 | 01:15 PM
Car: 87 TA
Engine: 355
Re: Belt Alignment
Thats the thing, none of the p/s belts match up because I removed the a/c
Old Nov 26, 2009 | 01:22 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
Re: Belt Alignment
thats weird. the a/c is gone in my car and the pulleys line up fine. and i have a 85 t/a
Old Nov 26, 2009 | 04:22 PM
ploegi's Avatar
Engine: 5.7 TPI
Re: Belt Alignment
Stick some spacers behind the brakets to move it to where you need it to be.
Do you have both serpentine, AND v-belts there? W/P, Alt, and crank pulleys look to be Serp set up?
Old Nov 28, 2009 | 04:50 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: Belt Alignment
when you get it lined up, let me know how the tension is. i took the a/c out of mine, and for some reason the powersteering belt seems a bit loose
Old Nov 28, 2009 | 04:53 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
Re: Belt Alignment
I had some problems with my ps pulley when i got the car, there was no A/C and the the PS belt was to small and the brackets ended up crooked. I ended up just getting a bigger belt and putting a spacer behind the bracket.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
