305 Head Gasket Question
Old Nov 25, 2009 | 12:21 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I'm confused dang it.
If you mill down Vortec heads for higher compression on a 305, don't you use a 305 head gasket, since it's a 305 block?
No article I've read addresses WHAT gasket the builders use, when putting Vortecs onto a 305.
They babble about thicknesses and CR's but never say whether they go with a 305 gasket or a 350 gasket.
Does anyone know which gasket to use?
A 350 gasket doesn't make sense to me, but what do I know... ha
Thanks guys.
Old Nov 25, 2009 | 04:23 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 305 Head Gasket Question
I was always under the impression that the 305 and 350 gaskets were the same. But as you say "what do I know?"
Old Nov 25, 2009 | 08:27 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
That's weird because the bore is smaller on a 305.
Old Nov 25, 2009 | 01:54 PM
Guest
Guest
Posts: n/a
They are not the same gasket. You should use whichever fits the head better. You do not want the fire ring of the 305 gasket to fall into the chamber on the head, that would be bad.
Old Nov 25, 2009 | 02:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's getting harder and harder to find a 305-specific gasket these days.
One is Felpro Q505SD.
Old Nov 25, 2009 | 03:35 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Will those work with an aluminum head?
Old Nov 29, 2009 | 06:40 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I was told also that the FelPro Z1094 .015 is a good one, at least for my setup, which will be 305 specific Vortec Heads.
Old Aug 28, 2022 | 07:39 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Thanks guys.
If you are using the 350 L31 vortec heads or any other 350 head on a 305 use a 350 head gasket.. If you want a thin gasket use the felpro 1094 .015" shim 350 gasket
4.10" x.015" compressed.
dutch930
Sep 11, 2015 06:58 AM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
