Coil problems..
Old Nov 25, 2009 | 12:50 PM
AtreyuBigBlock's Avatar
Car: 1982 Camaro
Engine: 5.3 LS2 Top End Twin Turbo
Transmission: t56
Axle/Gears: Ford 9"
Coil problems..
Hello people. My car is in the process of a paint job right now, and yesterday i went to move it onto the painting platform at my work, and my car wouldn't start. It's an 82' with a 454 in it. I had H.E.I. in it origionally, but my distributor was crap, so i bought a Mallory Uni-Lite distributor and a Summit Racing Coil. I hooked it up (which im pretty posotive i had it hooked up correctly) went to start it, and had no spark. Then i walked away for a few minutes and the coil went up in smoke. So lucky me i have a million coils at my house, so now ill try one of those first. Does anyone know if the power wire form an H.E.I. will work with a coil, or do i need a resistor or ballast on that wire now? I could have also had a bad ground, but i would like to get some info first. Thanks
Old Nov 26, 2009 | 11:22 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Coil problems..
Do you have or could you post a link to the documentation of how its supposed to be hooked up? From there we could figure out how to hook it up properly.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
