Tightening Rocker arms HELP!!!
Old Nov 27, 2009 | 08:18 PM
t_long927's Avatar
Hey all I have installed a new cam and had a head job done. I need to know the sequenance to tighten the rocker arms down. I did it once now and bent a set of rods when I set the motor back to TDC.
Old Nov 27, 2009 | 08:57 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Tightening Rocker arms HELP!!!
http://www.thedirtforum.com/chevyvalves.htm
Old Nov 27, 2009 | 10:59 PM
t_long927's Avatar
Originally Posted by ploegi
Thanks a ton.. This will really help. Do you happen to know the torque specs
Old Nov 27, 2009 | 11:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock, or aftermarket?
Old Nov 28, 2009 | 02:33 PM
t_long927's Avatar
stock rockers but edelbrock cam. flat tappett by the way
Old Nov 28, 2009 | 04:16 PM
ploegi's Avatar
Engine: 5.7 TPI
No particular torque spec. Tighten the rockers until you cannot easily move the pushrod (some suggest in an up and down motion, other suggest trying to spin them....) When you can't move the pushrod, give the nut another half turn, and you are good. Once you have all the valves adjusted, turn the motor over a couple times BY HAND to verify that nothing is binding.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
