Ive always wondered this about cams.
Old Nov 28, 2009 | 09:25 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Could an aftermarket cam like mines(ADV. Duration (INT/EXH): 288 / 288
Duration @ .050" (INT/EXH): 214 / 214
Valve Lift (INT/EXH): .443 / .443
Lobe Centerline: 112
Power Range: 1700-5200.)
cam cause a starting problem or hard starting?
Old Nov 29, 2009 | 03:06 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Ive always wondered this about cams.
That cam installed and tuned correctly should not have a hard time starting.
Old Nov 29, 2009 | 08:04 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
what envolves tuning properly
Old Nov 29, 2009 | 08:30 PM
All the motor basics really same things you would tune on any motor. If its carbed adjust the timing and carb or if fuel injected the ECM reprogrammed to match your current set up. That sort of stuff.
92projectcamaro
Dec 8, 2015 12:25 AM
Bradsaundry
Oct 7, 2015 04:35 PM
loud91rs
Oct 5, 2015 10:05 PM
