quick compression test question
Old Nov 28, 2009 | 03:18 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
quick question, my grandfather gave me a compression guage that he had lying around, how am i supposed to test the compression? the headers get in the way, am i supposed to take the headers off to test the compression?
the reason I am testing is because I have 60cc chamber 305 heads on my 350, and I know that should get high compression, I just want to see how high.
thank you.
Old Nov 28, 2009 | 03:38 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: quick compression test question
shouldnt have to pull the headers....
Take out ALL the plugs. Screw the fitting for the gauge into one cylinder, and crank the engine so it rolls over five or six times. Check the reading on that gauge. Move on to the next cylinder.
Not entirely sure what the actual number should be, but, all cylinders should be within about 10% of each other.
Old Nov 28, 2009 | 04:40 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
i dont know how I am gonna do it without taking off the headers thou, like the spark plugs barely fit under the headers.
Old Nov 29, 2009 | 04:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
If you have to take off the headers in order to hook up the compression tester, then do so. It won't change your numbers. It just adds work.
Old Nov 29, 2009 | 08:23 AM
V3500's Avatar
You could get a hose with the right fittings.
Old Nov 29, 2009 | 09:53 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Disable the fuel and fire from the motor also.
Old Nov 29, 2009 | 04:41 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
yeah i know, I am gona remove the ignition coil and disconnect the fuel lines to the carb.
EDIT: I am supposed to hand turn the engine while someone holds the guage in the spark plug whole right?
Old Nov 29, 2009 | 04:46 PM
ploegi's Avatar
Engine: 5.7 TPI
If it doesn't have a screw in fitting, yep.
Old Nov 29, 2009 | 04:47 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
ok thanks guys!
Old Nov 29, 2009 | 05:54 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Hand turn?
Use the key.
Old Nov 29, 2009 | 06:19 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
i meant like hand crank it.
but its ok to use the key to turn it over?
Old Nov 29, 2009 | 07:44 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Don't have to disconnect the fuel lines.
Engine should be warmed up to get accurate readings but if your having time
issues between readings because of hookup time no biggie.
Open the choke on the carb with something while cranking, screwdiver
works good.
No spark a given.
HTH
Later
Old Nov 29, 2009 | 07:47 PM
ploegi's Avatar
Engine: 5.7 TPI
yeah, crank it with the key. unless you really need some exercise?
Old Nov 29, 2009 | 08:19 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
hold on, how can i warm up the engine, if theres no combustion how will the engine warm up?
and, if i disconnect the headers so i can fit in the gauge, will i have to worry about hot air coming out the exhaust ports and burning sh*t?
Old Nov 29, 2009 | 09:01 PM
jaykar's Avatar
Like I said, if there is a problem with with time restraint because you
have to work around problems, no biggie.
But the correct way to do it is with a warmed up motor.
Exspansion, clearances, ect.
Warm it up before you start taking things apart.
Later
Old Nov 29, 2009 | 09:16 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
ok, someone mentioned getting a hose with fittings on it, where would i look for that?
Old Nov 30, 2009 | 10:18 AM
ploegi's Avatar
Engine: 5.7 TPI
Auto parts store would be the place to look first.
Old Nov 30, 2009 | 01:07 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
ok. thanks.
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
