oil on spark plug
Old Nov 26, 2009 | 11:03 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
oil on spark plug
I changed the valve seal and tightened the intake
motor is fairly new
I need some help with diagnostics before I tear it apart for some new rings on number 3 piston
thanks
Old Nov 26, 2009 | 11:07 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: oil on spark plug
Compression/Leak down test will tell some tales.
Old Nov 27, 2009 | 08:17 PM
jamon8's Avatar
Engine: 350 tpi
just did a compresion test and all cyl are 210
I dont want to tear it apart when it is running so well
thank my lucky stars that it is the easiest plug to get to
I think I will just buy a new set of plugs to put in after the comp test and clean the old ones up and use them in numb 3
I was going to go to synthetic oil would that hurt my compession by making it too slick
I think I must have put the second ring on upside down or the oiling rings got messed up or something
bottom line is I just dont want to have to take the motor apart right now
Old Nov 30, 2009 | 01:19 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Same issue here number 1,3 and 7 plugs are loading up with oil something horrible.
and wot produces tons of smoke. was hopeing it wasn't the rings but that's what im preparing for.
Old Nov 30, 2009 | 01:43 PM
ploegi's Avatar
Engine: 5.7 TPI
Possibly a manifold gasket leak on the bottom side, letting is suck air/oil from the lifter valley in to the cylinders.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
