ROCKER ARM CLEARANCE
Old Nov 30, 2009 | 10:52 AM
KAPSHOTS's Avatar
Recently I have been working on a 350 ci engine purchased from ebay equippped with new Dart Iron Eagle Heads, later purchased Crane Cam roller rockers, Im having an issue witrh clearance. I don`t know what brand the springs are or if they came as a set with Lunati cam that was installed, or if the heads were purchased assembled.I was wondering if anybody has aver come across this clearance issue before?
Old Nov 30, 2009 | 10:55 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: ROCKER ARM CLEARANCE
Where are you having clearance issues? Spring to rocker? Rocker to valve cover? Have the correct length pushrods?
Old Nov 30, 2009 | 12:28 PM
KAPSHOTS's Avatar
Valve to spring, they wont go on to the stud without extra effort. the engine was equipped with roller tip rockers when purchased
Old Nov 30, 2009 | 12:54 PM
ploegi's Avatar
Engine: 5.7 TPI
Now I am really confused.... Are you trying to put the springs on the studs? Or, will the rockers not go down far enough on the stud that you can get the nuts on?
Old Nov 30, 2009 | 01:34 PM
KAPSHOTS's Avatar
the spring seems to be too fat to allow the rocker to go down on the stud.The rockers do not go down far enough to to bolt them on
Old Nov 30, 2009 | 01:42 PM
ploegi's Avatar
Engine: 5.7 TPI
This is where a picture would have been really helpful.
What diameter valve springs ya got? Aluminum, or steel rockers? (the new ones..)
Old Nov 30, 2009 | 02:24 PM
KAPSHOTS's Avatar
aluminum rockers crane cam part# 11744-16
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
