Fuel Pump and TPS
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Fuel Pump and TPS
Just a wild question here guys, but is the TPS position relevant to how much pressure the pump is putting through the lines on TPI?
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Fuel Pump and TPS
nope. only thing that alters fuel pressure is manifold vacuum, as vacuum goes down, pressure goes up. (higher throttle opening equals higher fuel pressure.) TPS is completely uninvolved.
92camaroJoe
Aug 13, 2015 06:07 AM
