flooooooooooding
Old Dec 3, 2009 | 03:06 AM
zAnToNiOz's Avatar
Car: 1986 red camaro i-roc z28
Engine: 5.0L 305 TPI
flooooooooooding
ok i got my camaro and when i drove it it was really rough so i did some routine checks and tune ups and ran into the fuel line which had been completely twisted around so i went on a journey finally got it fix then it started smelling like gas and not even giving a bite when i tryed to start it so i looked into it and i wondering if its true that well i took all of the spark plug wires off turned the key to the power position and used a test light on the two and only wires on each injector and the light stayed solid and apperently this means there constantly pushing fuel so im wonder if that was true and bad. the ninth injector didnt stay or go on unless i obviously turn the engine over thankfully but im wonder what would cause the injectors to stay on? could it be the ecm and how do i check if it is. how do i check the problems you guys hopefully narrow it down to also?
THX
Old Dec 3, 2009 | 10:53 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: flooooooooooding
What is your fuel pressure at?
Unplug the connectors from the computer, and see if you have a short to ground on the injector harness.
Old Dec 4, 2009 | 03:47 AM
zAnToNiOz's Avatar
im not sure what the pressure is at.
thx>
Old Dec 4, 2009 | 10:04 AM
ploegi's Avatar
Engine: 5.7 TPI
Should be able to borrow/rent a fuel pressure gauge from one of the local auto parts stores.
Old Dec 5, 2009 | 02:44 AM
zAnToNiOz's Avatar
okay ill rty to find one and can i use it if the cars off it wont start
