Odd clunking-grinding sound when making a right turn.
Old Dec 7, 2009 | 05:17 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Nine out of ten times when I make a right turn I hear and feel this clunking-grinding sound coming from the front drivers side of the car. Yesterday I had to slam on the brakes to a complete stop from 50-0, after that the sound was constant for about 1/4mile down the road. This makes me think it has something to do with the brakes or suspension. I replaced all the pads and calipers about 11 months ago and all 4 rotors look smooth. Recently I have also been noticing a shake and pull to either the left or right when I brake at high speed (i.e. on the highway when someone cuts you off ). But I don't know if that has anything to do with it. I apologize if this is in the wrong board, but I'm unsure if it's a brake issue or not.
Old Dec 7, 2009 | 05:30 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Odd clunking-grinding sound when making a right turn.
Check that your wheel bearings are still properly adjusted.... and that the caliper bolts didn't decide to back themselves out...... Did you turn the rotors when you did your brakes? Do you get any kind of pedal pulsation with the brakes applied?
Old Dec 7, 2009 | 05:39 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
i just replaced my own bearings(inner & outer), calipers, and while she was tore apart, new pads. Big difference!
Old Dec 8, 2009 | 07:34 AM
oifish's Avatar
Engine: 5.7 TPI L98
I'll check at the bearings this weekend. Any tips for removing them? And I did have the rotors turned, and I haven't noticed and pulsation in the brake pedal.
Old Dec 8, 2009 | 08:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The bearings will fall out. You'll have to drive the races out.
JamesC
Old Dec 14, 2009 | 04:30 PM
oifish's Avatar
Engine: 5.7 TPI L98
Replaced both the driver and passenger side inner and outer bearings, and greased up all the joints. Also I decided to completely bleed and replace all the brake fluid, which I found bits of dirt and junk in my brakes lines. Now the problems seem to be resolved, hopefully it stays this way. Thanks for the ideas.
Old Dec 14, 2009 | 04:58 PM
Good to hear!
Old Dec 18, 2009 | 02:17 PM
oifish's Avatar
Engine: 5.7 TPI L98
Arrrghh. The sound is back. The shaky brakes and pulling to one side or the other is gone. It almost feels like the brakes don't release all the way. Could this be related to the master cylinder at all?
Old Dec 20, 2009 | 09:36 AM
vette gator's Avatar
Car: 85 Z28
I didn't see that you replaced the flex lines. Since you've eliminated most of the other strong possibilities, I wonder about them. It might explain the junk that later came out during bleeding and the feeling like a caliper isn't releasing.
Old Dec 20, 2009 | 10:50 AM
Twin_Turbo's Avatar
Check the tranny mount, mine had 2 of the 4 holes holding it to the subframe stripped and the bolts were real loose, clunked like a ***** and I could swear it came from the front when driving
92camaroJoe
Jul 29, 2023 07:57 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Warlocksirix
Sep 3, 2015 12:26 PM
92camaroJoe
Aug 13, 2015 06:07 AM
BrianI
Aug 9, 2015 11:52 AM
