Yet another car will not start.
Old Dec 12, 2009 | 11:26 PM
427F-Bird's Avatar
Car: 1986 Firebird / 1991 Formula
Engine: 350 4BBL / 305 TPI
Transmission: 700 R4 / T 5
Axle/Gears: 9-Bolt Posi / 10 Bolt Posi
1991 Formula, 5.0 TPI /T5.
So basically, after a 10 minute drive today, my car stalled, and now will not start. I'm currently thinking that the fault is somewhere in the ignition system. What it's doing is that when the key is turned, no lights such as the SES, seatbelt, or e-brake lights in the guage cluster come on, and it will not crank. I do not hear the fuel pump priming either. Nor does the fan, which is wired to the ignition, come on. The car had the VATS system at one point, and its been disabled by a previous owner. My current thoughts are that either a fuseable link in the area of the starter has blown, or a starter wire is loose, but currently I have no way to check it. Basically, im searching for other ideas. I've checked the fuses, and wires I can get to, but I'm looking for other things it could be. All the exterior lights work, and the guage illumination lights work, but the door buzzers, radio, and the indicator beeping to tell you that your lights are still on do not work. What else could I be looking at? Thanks in advance for any help.
Old Dec 13, 2009 | 08:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Yet another car will not start.
Disabling VATS means inserting a resistor to fool the VATS module into seeing the resistance it's looking for all the time ... so my first thing would be to verify that that resistor didn't come disconnected.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
86Base
Aug 8, 2015 01:34 PM
