LT1 intake on 305?
Old Dec 16, 2009 | 04:18 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
LT1 intake on 305?
Hey guys, I was just wondering if it's possible (or even worthwhile) to put a LT1 intake on a 305 engine. I have a 91 T/A with a 305 TPI engine and I noticed that the LT1 intake looks pretty similar. I know that 350s usually have that intake so that's why I'm asking. Or would I be better off just using an aftermarket TPI intake? What would an LT1 intake require?
Old Dec 18, 2009 | 10:29 PM
Engine: LB9
Re: LT1 intake on 305?
bump... is this a dumb question?
Old Dec 20, 2009 | 01:20 PM
Vader's Avatar
It is possible, although you will not have an EGR valve when finished. The LT1 intake can be adapted to any Gen 1 SBC, including the 305. It's not a vain effort, either. That same intake on a "lowly" L99 (only 265 cubes) in 1994 allowed the little engine to make 200 HP and 245 lb·ft - More power than an earlier 305 TPI on 40 fewer cubes. It certainly can't hurt the 305 if paired with the right cam and heads. Best of all, you can always bolt it onto a 350 (or larger) SBC in the future.
There WAS fairly decent information on the www.LT1Intake.com site but that appears to be defunct now.
Old Dec 20, 2009 | 02:27 PM
Engine: LB9
Gotcha. So you're saying it's a bolt-on for a 350 engine?
Old Dec 20, 2009 | 02:35 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Get the TPIS Miniram intake. Same design as the LT1 with provisions for a distributor.
Old Dec 20, 2009 | 04:19 PM
Engine: LB9
yeah the mini ram intake looks sick. the company has outrageous claims too... gains of 75-95 hp on a 350?! I wonder how that would work out on a LB9 (305) like what I got.
http://www.tpis.com/index.php?module...niRam+Manifold
Old Dec 20, 2009 | 09:18 PM
RSFreak's Avatar
They used to say "not for use on 305s", but thats probably 'cause you won't see the same kind of gains with the smaller engine.
Old Dec 20, 2009 | 09:41 PM
Engine: LB9
Maybe... depends on the cam too I guess. Are 305s capable of putting out decent power? Who knows, I was hoping to get close to 300 hp with my 305 some day with bolt-ons. Fuel injected of course. Passing emissions would be nice too.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
