tpi with a cam
Subscribe
Dec 16, 2009 | 06:16 PM
i have a 86 irock 305 tpi im switching to a 350 i built with aluminum heads iv herd so far i would have to up grade the injectors but the main question is is it posible to use a lower vac cam with the tpi set up or should i just change it to carb
Reply 0
Dec 16, 2009 | 07:18 PM
Re: tpi with a cam
If you want to retain the TPI, you'll need a new ESC module, knock sensor, injectors, and a new tune on the computer.
What cam do you have in the new 350?
Reply 0
Dec 16, 2009 | 07:48 PM
Re: tpi with a cam
i dont have a cam in it at the moment but i def wanna go bigger than stock was looking at the 12-242-2 comp extremem energy cam
Reply 0
Dec 16, 2009 | 08:20 PM
Re: tpi with a cam
With the tpi I would go a little wider on the LSA, and look into the comp extreme fuel injection cams. One comperable would be the 12-366-4. About the same duration, gobs more lift, and a wider LSA.
http://www.compcams.com/Cam_Specs/Ca...?csid=121&sb=2
Reply 0
Subscribe
