92 Speedo Jumping around
Old Dec 17, 2009 | 10:34 PM
Charles_R_H's Avatar
Car: 1992 RS 25th An
Engine: 5.0 TBI
Transmission: 5 Speed Manual
I bought a 92 RS 305 TBI, (110mph speedo), about a month ago and have been working out a lot of bugs. I was able to get cruiz to work fine by re-running some vac lines that had been plugged up by who knows. All gauges are working fine, except the speedo. Sometimes it stays burried one direction or the other. Sometimes it pings around erratically. Every great once in a while it works fine for a second or two. If I have a cruiz controll, odometer, and trip that work fine, I don't know where the speedo issue could be, but in the gauge itself. On this car, the vss is on the driver's side rear end of the tranny. There is a gear on the vss that looks okay. I pulled that out the other day and almost got a face full of fluid. I pulled the gauges and they are all enclosed. There are just connects that kinda plug in when you screw the gauge assembly in place. contacts do not appear to be dirty. Again, cruiz, odometer, and trip seem to all work fine. I was in the 12 volt field for about 5 years at one point in time and don't have any issues with taking stuff apart and re-soldering any contacts/traces/components/replacing electronic components. I just wonder if I should try or go looking somewhere else first. Thanks for any help!
Old Dec 18, 2009 | 01:09 AM
91RS_Charlotte's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.42 Std
Re: 92 Speedo Jumping around
If you know anyone with datalogging capabilities, you can see if the ECM is getting a speed reading, it would really help to point you in one direction or another. If you don't, it only takes an ALDL/USB cable, a laptop, and some shareware to do it yourself.
I have the same problem and have narrowed it down to the plastic film circuit on the back of the instrument cluster. Just haven't gotten around to replacing it as I am still finishing an engine swap.
Best of luck!
Old Dec 18, 2009 | 06:56 PM
Engine: 5.0 TBI
I pulled the gauge cluster out again, and am currently testing continuity between all traces / connections. I'll let ya know if I find anything interesting.
Old Dec 18, 2009 | 07:57 PM
Engine: 5.0 TBI
I didn't find any bad traces/connections. circuit board that has a 4 pin connector that goes to needle mech didn't have anything bad/burned that jumped out at me.
Old Dec 18, 2009 | 08:00 PM
Engine: 5.0 TBI
I guess question is now does VSS control cruiz, odometer, or trip meter. If it does then I know not to buy $125 VSS.
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
