2 v belt to serpentine questions
Old Dec 18, 2009 | 04:40 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Okay, trying to start on the conversion to a serpentine setup since its much more efficient. I have a 2 belt setup; belt 1 - Alternator, water pump, crank. Belt 2 - Power steering pump, crank, water pump.
Is there any setup that would just allow me to change the pulleys and retain the same water pump or would all of that need to be changed?
Old Dec 18, 2009 | 05:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 2 v belt to serpentine questions
The water pump will be reverse rotation. Perhaps something in the following link will be helpful:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Dec 18, 2009 | 09:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Is your alternator on the pass side? If so, just swap pulleys to those on the 1/2 serp 1/2 v-belt setup. That way, you can keep your standard rotation water pump, and have serp belt on the important part - the alternator.
I have a 1992, and I hated the serp setup - big ugly brackets. I swapped over to the 1/2 & 1/2 setup and I love it! Nothing "inefficient" about v belts - they've been making cars run for the last 100 years!
Old Dec 19, 2009 | 07:04 AM
JamesC's Avatar
I'm always amused at our human condition and its variables. I swapped to serp bcause I thought the V belts were ugly (and I felt they they cluttered up the bay)
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
