24# injectors
Old Dec 18, 2009 | 06:19 PM
tealcamaromanrs's Avatar
Car: 1991 camaro z28 convertible
Engine: 383 tpi
Transmission: t5
24# injectors
what kinda upgrades do i need to do to upgrade my injectors to 24# if any??? 92 350 tpi camaro
Old Dec 18, 2009 | 07:37 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: 24# injectors
you need to change the fuel injector constants in the PROM or it will be running rich.
Old Dec 18, 2009 | 08:29 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 24# injectors
It will run a little rich in open loop, but in closed loop it will be fine. Run a heated O2 sensor and it will get there in a couple minutes.
Old Dec 18, 2009 | 10:34 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: 24# injectors
The ECM should be able to adjust thefuel delivery down about 16%. The flow rate between the 22s and 24s is about 9% different. So you should be OK in closed loop mode, as jv9999 has stated above.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
