Vacum line
Old Dec 21, 2009 | 08:04 PM
dynodave52's Avatar
Car: 88 IROC Z
Vacum line
While looking over my 88 iroc with TPI 305 i just bought i noticed a vacum line with a screw in the end of it. It was lying under the throttle body,i dont see a place to hook it back up,there is a line on each bib i looked at,including the one under th T.B. I followed it back and it goes into the firewall into the car with another line that is hooked up. Its one of those small,maybe 1/8 in. hard plastic lines.I know the air ducts work on vacum so i tried them out,and the defroster comes on and blows,and the dash duct blows,but i dont get any heat to come out when i slide the **** over to heat.The vacum diagram only shows the hoses related to emissions.Any one know where i might find one with all the hoses,or know what this line is ,and where it goes?
Old Dec 22, 2009 | 12:32 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Vacum line
Look at the pics for a heater diverter valve - then see if yours has a vacuum line to it.
Old Dec 22, 2009 | 01:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Vacum line
This diagram shows the line under the plenum supplying vac to the vac pots on the tank purge system
http://www.chevythunder.com/fuel%20i...INE%20DIAGRAMS
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
