RPM's
Car: 92 Camaro RS
Engine: 3.1 V6--454 BBC in the works
Axle/Gears: Stock 3.23
RPM's
What are the normal RPM's at idle for 3.1 V6 cars? How about at 70mph?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: RPM's
IIRC, the idle speed should be listed on the sticker on the underside of the hood. Theres really no adjustments you can do, other than the min air adjustment.
Car: 92 Camaro RS
Re: RPM's
Thanks. I think my trans might be on the way out in addition to that. When I started the car (cold) and drove it without warming it up, the rpm's went up to about 3500 and held there until I let off the gas and got back on gently. Then getting on the expressway the rpm's got near 4000 and I was only at 55 mph. Usually while I'm cruising at 70mph the rpm's will stay around 2700. Is this too high?
Elephantismo
Feb 13, 2019 12:51 AM
Damon
Sep 26, 2015 04:29 PM
