any one run the Elgin E-922-P
Old Dec 22, 2009 | 02:39 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
so i got a 350 just to run in my car for a while untill i finish my forged 383 and get my turbo going.
my question is has anyone on here run the E-922-P camshaft in there 350??? I have it layin around so i was just going to toss it in and run it. with a gear drive. its going in a 010 4 bolt main with camle hump heads i picked up for 100$ in good running condition.
specs are
http://catalog.elginind.com/app/Engi...gh+Performance
Old Dec 22, 2009 | 01:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Can't say I have any experience with it, but looks like a lot of duration for the lift. 1.6:1 rockers would help a little, but camel humps probably don't benefit much from more lift.
Why a gear drive?
Old Dec 22, 2009 | 03:29 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Re: any one run the Elgin E-922-P
well i actally pulled apart another 010 motor to build a 383 but thats going to take a bit of time since me and my wife just had out first baby on the 18th so i got this motor just to put in there to run untill i get my rods and pistons. i have the crank fly wheel and blancer and the block is ready.
i have that cam just sitting here and might aswell use it. and the gear drive i got for my jeep but i never installed it so might as well use it.
i was told the cam is more of a rv pulling or gas friendly cam for the 350.
my plans are just to use my holley 650 dp carb i have the headderman headders and y pipe for my cal already a edelbrock performer intake and run it untill i finish my motor.
Old Dec 22, 2009 | 04:11 PM
five7kid's Avatar
Congrats on the new addition to the family. First? Your life will never be the same (and that's a good thing).
My mistake, I only looked at the advertised duration, not the 0.050" duration. It isn't all that wild. Should be fine. Performer intake as well.
I'd still put a double roller timing set on it, though. If the gear set is unused, now is the best time to sell it and get more performance for your $'s (when the denominator gets smaller, the quotient gets bigger).
(For the record, it's "Hedman" and "hedders" {Hedman only - everyone else has "headers" }.)
Old Dec 22, 2009 | 07:48 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
thanks it amazing an how life changes so fast
i installed the gear drive today i figured that i would use it since i already got it out, and it saves me buying a chain i changed the cam and lubed every thing tomarrow i have to get all the gaskets
but i found out that the motor has been gone though and it has .30 over trw forged pistons and the old school pink rods and a forged crank so it was a good buy for 100$ and everything was clean and the pan was clean and no smell of burnt oil..
i am going to paint everything flat black so it looks like the old l69 305
i hope to get it in the car this weekend
Old Jan 14, 2010 | 09:04 AM
Foxhall1337's Avatar
Car: 1989 Formula ws6
Engine: 305 TBI
Axle/Gears: Detroit Locker 3.73
i am currently running this cam and it is actually a nice pic the computer needs a little tune other than that i have an 89 firebird with a 94 k2500 crate motor this cam and a 373 and this thing moves the cam has a slight choppy idle it will missfire up to about 1300 rpm then it cleans up and launches the only issue i have like i said the computer adjusts out the cam
and i get a knock sensor code when i let idle for a min ;-)
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
