327 rocker question
Old Dec 24, 2009 | 07:41 AM
kingzrt's Avatar
Car: 1987 IROC-Z
Engine: 5.0 305ci 4 barrel Edelbrock carb
327 rocker question
I have an 87 Iroc with a 327 in it, i pulled the valve cover off the other day to clean for paint and noticed one of the rockers is not sitting square on the valve spring. Is this a big deal? I have never seen anything like that. What is the solution if it is a problem? Thanks for the help
Old Dec 24, 2009 | 10:27 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 327 rocker question
What are the head casting numbers? I'd guess you have heads that need self-aligning rockers but have regular ones. Best not to leave it that way.
Old Dec 26, 2009 | 08:25 AM
kingzrt's Avatar
Car: 1987 IROC-Z
Thats the interesting part, the number is 14022601, i found it comes from either a 305 or a (267) which i doubt. After pulling the Passenger side valve cover off i found 1 Rocker on that side also not centered.
3.8TransAM
Sep 3, 2015 06:38 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
