83 trans am fuel sending unit-please help!!!!
Old Dec 26, 2009 | 12:38 AM
jtraynor86's Avatar
Car: 1983 T/A
Engine: 454 BBC
Transmission: Built 700R4
Axle/Gears: Weak 10 Bolt/3.23
Well here's my problem, I have a 83 trans am that I'm trying to get running and I've ran into a snag. I'll start by saying that the car sat for about seven years. I am trying to replace my fuel sending unit but it seems as if I can't find any for my particular year. My trans am has the crossfire TBI 305. Does anyone know where to find one or are there any other years that would work with my particular application. Also does anyone know what might cause the fuel sending unit to be recieving low voltage from the circuit. Bad fuel pump relay maybe. Someone please help!!!!
Old Dec 27, 2009 | 10:58 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: 83 trans am fuel sending unit-please help!!!!
Well a few things here:
1. The fuel gauge sending unit is just a standard 0-90 ohm sensor. Although there may be differences in how its installed between different years any one that will physically bolt in and has the 0-90 ohm sweep will work.
2. Second the sensor will not receive 12V. The way it works is the gauge and sensor act as a voltage divider which acts kinda like a tug of war over the needle to read fuel level.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
beachrodder
Aug 25, 2015 08:05 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
