Battery Keeps Dying
Old Dec 26, 2009 | 08:38 PM
pcarrell's Avatar
Car: 1985 Camaro Sport Coupe
Engine: 305ci
Battery Keeps Dying
I have an 85 sport coupe with a 305 4bbl under the hood. Been running pretty good up until now. My battery is a bit less then a year old and recently the car gave the dead bettery clicking noise. I knew the alternator was older then dirt and the bearings in it were bad, so I swapped it out. I drove for a bit, and got the clicking again. I rocked the battery around a bit and got it to start. I went home and threw it on the battery charger, and it ran good for a few days. Now I'm back to clicking. The belt on the alt. is fine and adjusted right.
So, I'm thinking dead cell in the battery, or voltage regulator........what do you think? If it's the voltage regulator, where is it on this thing?
Any ideas?
Old Dec 26, 2009 | 08:46 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Battery Keeps Dying
well your alternator should only have two wires for the plug in on top. plus a main battery wire on the back. if so the regulator is built in. as for wiggling the battery and it starting i would say you need to check and clean all the connections. turn on the headlights and see if they go out when you try to start it. you know that auto parts will test the battery for you for free.
Old Dec 26, 2009 | 08:49 PM
Damon's Avatar
Clean all the cable connections (at the battery, the engine-side ground and down by the starter), recharge and try again. Have the battery tested as well.
If all that checks out, you probably have a slow draw somewhere in the system that's killing it after sitting overnight.
Old Dec 26, 2009 | 08:53 PM
one92rs's Avatar
Car: SOLD!!!!!
after you clean all conections remove the negative battery cable at the battery. put a 12 volt test light between the cable and the battery connection and see if it lights up. if it does you have a power draw. begine by removing fuses and unplugging the alternator.
Old Dec 27, 2009 | 07:17 PM
pcarrell's Avatar
Engine: 305ci
Thanks guys!
I cleaned the connections today and she's charging now. I'll play with it tomorrow night some more to see whats up with it.
Old Dec 27, 2009 | 10:20 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
I had the main wiring harness short at the spot where it comes thru the firewall, rubbed a few wires thru, fyi. good luck.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
