is this a good camshaft for my 383
Old Dec 28, 2009 | 11:10 PM
Goany's Avatar
im looking at this camshaft here r specs
INTAKE EXHAUST Valve Adjustment (Lash) - HOT .026 .026 Gross Valve Lift .546 .565 Lobe Lift .364 .377 Advertised Duration at .020 tappet lift 294 300 Duration at .050 tappet lift 256 264 Valve Timing At .050 Open Closed Intake 28.0 BTDC 49.0 ABDC Exhaust 61.5 BBDC 22.0 ATDC
Old Dec 28, 2009 | 11:14 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: is this a good camshaft for my 383
what brand of cam, and what is the grind number just out of curiosity?
Also what lobe serperation and rpm operating range??
and are you running carb or FI?? Tranny type and stall speed?? rear end gear?? car weight?? type of racing or street use?? Need more info.
Old Dec 28, 2009 | 11:39 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
That is a fair size camshaft. What are your goals for this motor?
Old Dec 29, 2009 | 01:17 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
256 /264
Forget about idle quality
That is a serious cam even for a 383 ; hope you plan on low diff gears, a manual or a hi stall convertor so it will work
Old Dec 29, 2009 | 01:36 AM
Goany's Avatar
no stall beefed up 700r4 2.29 gear rear end and sorry i dont got lobe separation thats all the seller had listed but its part number is RA 102 3500 to 7200 operating range. I do plan on buying at least a 2500 stall
Old Dec 29, 2009 | 02:38 AM
383RAT's Avatar
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
With durations and overlap in that range your 383 motor is probably going to need at least 10 to 1 compression ratio too. I recommend visiting Lunati's cam sizing program on their website.
Old Dec 29, 2009 | 06:31 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Goany
2.29 gear rear end .. plan on buying at least a 2500 stall
Going to be a pig .
Engine will stall at 2500 but cam doesn't come in until 3500 ? With those gears you have to be doing 40MPH in 1st before the cam comes in.
What have you got in your engine that makes you think you can spin it to 7K?
With a 2.29 rear ; are you going to Bonneville?
6000 rpm with T700 and 2.29 rear =284MPH
Caspar
Jun 19, 2016 11:19 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
Jake_92RS
Aug 17, 2015 09:42 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
