need help starter problem
Old Dec 30, 2009 | 06:00 PM
srosscamaro@aol's Avatar
Car: 85 trans am
Engine: 5.7 goodwrench edelbrock everything
Transmission: t-5 stage 2 clutch
Axle/Gears: 3.27 posi
the problem with my car is as soon as i hook up the batterycable the stater starts spinning with the key off whats the deal?
Old Dec 30, 2009 | 09:24 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: need help starter problem
Somehow there must be a short on the start terminal on the starter to 12V. Could be a bad ignition switch, bad starter, wiring fault, Or maybe someone just installed the starter wrong. Ide start by taking the wires off the start terminal on the starter and hook up the battery. If it spins you have a starter problem if it doesnt measure the voltage on the wire you pulled from the starter i imagine there will be 12V there and there should not be. Try it out and well go from there.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
