avoidable breakdowns !
Old Dec 31, 2009 | 08:18 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
so i was wrenching on the bird today and my dad rolls up in his ford diesel , shuts it off goes inside and comes out to start it again and WHAM !!! , this loud grinding noise and the diesel wont start . so i asked him , you ran it without oil again didnt you ? , he says , cant remember the last time i put oil in it , so what im thinking is that his engine is seized thus it is to much for the starter to handle . he poured in some oil and tried it again and no luck , just grinding nois . is there any way to un-seize it ?
Old Jan 1, 2010 | 12:17 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: avoidable breakdowns !
you sure the starter's not broken. and it sounds like time for an overhaul.
Old Jan 1, 2010 | 08:35 PM
it's an 03' diesel , and he said when he started the truck " 20 miles away from home " he heard a snap .
Old Jan 1, 2010 | 09:01 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Starter break @ a bolt? Flexplate snap @ the crank bolts?
IDK- start at the easy stuff first. I'm sure the oil level was checked by now??!??
The last time my starter was grinding was because there were some teeth breaking from the flexplate while it was trying to start!!
Good luck!!
F.I. 57 Belair
Aug 23, 2021 01:09 AM
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
2012sergen11
Oct 13, 2015 07:38 PM
project89
Sep 22, 2015 09:35 PM
E_S
Aug 29, 2015 04:09 AM
