1971 heads on an 87 block?
Old Jan 2, 2010 | 12:57 AM
305forever's Avatar
Car: 98 blazer 4x4 lifted 3inches
Engine: 4.3
Transmission: auto
Axle/Gears: idk, but not a posi
i found a set of heads off a 350 camaro (1971) and i was wondering will they be able to fit on an 1987 350 block or is their a slight difference? thanks
Old Jan 2, 2010 | 02:32 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1971 heads on an 87 block?
Bolt straight on but
May not have the correct bolt holes in front of head for late accessories
You need early style (perimeter) rocker covers
You may have to slot the two center holes on the intake if your current engine has the late style cast iron heads with 72 degree bolt angle
Old Jan 3, 2010 | 11:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
'71 heads will have the right bolt holes for accessory brackets. That change started in 1969.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
lakeffect2
Aug 23, 2015 08:44 AM
