camshaft help
Old Jan 3, 2010 | 01:27 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
Transmission: tko 600
Axle/Gears: 12bolt 3.73
camshaft help
ok i need help here. i put a new edelbrock cam in my 355 and my fuel pump isnt working. could it be that my new cam didnt come with a fuel pump lobe?
Old Jan 3, 2010 | 02:30 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: camshaft help
what year is motor, what is cam grind number, need more specs.
Old Jan 3, 2010 | 04:00 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: camshaft help
Are you saying that your car has a mechanical fuel pump?
These cars typically have an electric fuel pump.
Old Jan 3, 2010 | 08:36 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
Re: camshaft help
its not the stock motor. and its a edelbrock 426 lift cam
Old Jan 3, 2010 | 11:23 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: camshaft help
if its mechanical, you have to remove the fuel pump to pull the old cam, im pretty sure all the edelbrock cams have fuel pump lobes. are you sure you put the fuel pump pushrod back in?
Old Jan 4, 2010 | 01:55 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
Re: camshaft help
i put the push rod in and the fuel pump is new
Old Jan 4, 2010 | 11:14 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Re: camshaft help
did you check to see the fuel cam lobe is under load when you installed the cam?
there is a spring actuator in the mechanical fuel pump. you may have wrong length actuactor for the cam.
if you disconnect the fuel line to your carb and crank the
motor does gas pump out?
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
