Getting codes 21,33,45,
Old Jan 4, 2010 | 11:42 AM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
I have a 89 camaro iroc 350TPI and the car won't ilde unless I hold down the gas and then it will stay running...new fuel pump,new fuel press reg,tune up...pulled some codes and they were 21,33,45..and another was something to do wit the egr valve...almost done putting the new one on..need help wit the other codes...the cats were cut off as well...
Old Jan 4, 2010 | 11:11 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Re: Getting codes 21,33,45,
code 21 - TPS voltage high when MAP reads low pressure
code 33 - MAP reads high manifold pressure (low vaccum) with the throttle angle is <=2% (read from the TPS)
code 45 - O2 sensor reads rich exhaust condition and that can be for a number of reasons
I think the three codes are indicating a TPS Issue. I would start by checking the voltage on your TPS low/high of .54/4.5
Old Jan 5, 2010 | 02:58 PM
alright so this would be my first time adjusting it..I know how to jump and all that..so if it's over 4.5 it's to high then bring it down to what
Old Jan 7, 2010 | 12:55 PM
I checked the tps and it was .55 to almost 4.5v
Old Feb 6, 2010 | 03:10 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
i had an issue with my TPS also. With the engine idling, try to wiggle the connector, if the idle changes it is most likly a loose connection. To solve this I took a skinny needlenose pliers and pinched the connectors in the TPS a little bit and it took care of the problem.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
