powersteering pump removal
Old Jan 6, 2010 | 06:54 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i been racking my brain able removing my powersteering pump to free up some belt h.p. what all is needed to run with out one? can i just plug the holes on the steering column area, or do i need some other things to run "manual" steering?
Old Jan 7, 2010 | 02:42 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
Re: powersteering pump removal
unless you're running skinny front tires, and this is a drag-race only car, i.e. you'll never ever have to parallel park, i'd recommend you keep the PS. just my 2 cents, that's all.
I went to manual steering on a vette, it has wide tires (255), "sports" steering box ratio, and requires parallel parking. it is no longer really street driven, it's a bear to drive. in retrospect, not a good decision, and unfortunately, not easy to undo.
now of course, on a slant-6 Valiant, manual steering not a problem: econo-tires, many-turns lock-to-lock, light-weight on the front end.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
